Guest Anonymous Posted September 29, 2002 Share Posted September 29, 2002 Think I've got this figured out, but would appreciate any comments from "the experts" before I terminate and mount everything. I'm in the middle of installing a remote battery, remote solenoid, and MSD ignition as part of the V8 conversion in my '77 280Z. Main question concerns the big white wires and the big white/red wires. I'm thinking the Datsun fusible links stay as they are, the big white (was starter wire) gets hooked to the hot side of the remote solenoid switch and the red/white get hooked to the Alternator output post. That sound right? FYI, and probably more than you want to know, the rest of the stuff is being hooked up as follows: "00" gauge welding cable from battery+ to remote solenoid and from solenoid to starter; "00" gauge cable runs from battery- to original ground location in engine bay; jumper between starter terminal and old solenoid terminal; jumper wire from alternator output post to one of the voltage sensing wires in alternator side-connector; blue wire for alternator charge warning circuit goes to other voltage sensing wire in alternator side connector; black/yellow wire from ignition goes to small right-hand post on remote solenoid; MSD wired per standard instructions with small red MSD wire going to hidden "theft control" on/off switch. Quote Link to comment Share on other sites More sharing options...
pparaska Posted September 30, 2002 Share Posted September 30, 2002 Todd, I don't think it much matters if you run the Big white or Big white/red wire to the positive battery cable side of the solenoid, or the alternator output. In fact, use a big wire from the alt output (with the proper fusible link or fuse) to the positive battery cable on the solenoid. The less drop the better. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 30, 2002 Share Posted September 30, 2002 That makes sense. The white and red+white wires are already connected to one another through the original Datsun fusible links. Attaching them to the hot side of the remote solenoid will be easy. Thanks for the peace of mind. Quote Link to comment Share on other sites More sharing options...
