Autometer elec. speedo issues
Running with the LT1 PCM.
I put the Speedo in calibration mode, drove the 2 miles and then hit the button again, but it doesn't zero like it's supposed to, it goes to full peg, like it's waiting to go into calibration mode again. If I switch off the car and then on again, it resets to zero, but doesn't move at all when driving.
Any ideas?
Tim
Tim, I used that speedo when I did the Tomahawk/LT1 swap. I e-mail Autometer for clearification on hooking it up. They said not to use the wire from the PCM but splice directy into the wire from the VSS. Maybe this is your problem.
I used a hand held GPS when I calibrated it. Worked perfect first time.
