Quick question about injectors and RB...
Guest Aguyandaredhead
Anyone know if there is a prefered injector upgrade for the RB25det? I also wonder if an upgrade is needed, I plan to run the stock turbo after a steel wheel is swaped out for the ceramic one at no more than 12 psi. I will be running Haltech's new E11v2 stand alone system. Also being fed by a Bosch fuel pump good for 255lph through #6 line with an aeromotive sump retrofit to my tank or possibly a fuel cell.
Any suggestions or helpful hints please speak up.
Thanks
Jeff
The stock RB25DET injector is good for 370cc/min @ 45psi. The Nismo upgrade 16600-RR710 is good for 480cc/min at the same pressure.
Based on those figures, you will be able to calculate the HP numbers that they support.
