4" Exhaust, DFW Area
Phantom
  • 3 weeks later...
Heya!
Are you SURE you want pipes that diameter? Seems like you're begging for resonance. And would it scavenge well? Seems like your exhaust velocity would be reduced quite a bit with all that volume in the pipes.
You know, I still need to see your car in person. You're so close, we should get together for lunch some weekend and you can show me your toy!
Scott
Forget the idea of a 3 1/2" from the current 'Y' pipe back. I dragged my 2 1/2" exhaust slightly leaving a Uhaul parking lot Tuesday evening. Fortunately I saw the problem and went over it very slowly so no damage.
I'm going to have to find a way to run 2 1/2" to aft of the R200 and then either find a dual inlet muffler or transition to the single 3 1/2 or 4 inch there and turn straight into the muffler.
Actually I've looked at "squashing the 3 1/2" down to 2 1/2" high by about 4 3/8" wide. Would work better from a flow area to do that with a 4" though. Finding someone that is that talented and can fabricate elbows and round to oval transitions is the challenge - not to mention the cost. Rectangular is another option but the flow characteristics are not as good as oval. It would be a bit easier to weld up though.
That all leads back to putting a 'X' pipe where the current 'Y' pipe is and running parallel 2 1/2" to behind the R200. Easy size for any muffler shop to work with and maybe just one funky transition to get to the muffler. It is a very close fit (what isn't on these cars) but there might be room for a magnaflow muffler, a sharp 3 1/2" 90° elbow to a dual 2 1/2" to single 3 1/2" Y pipe. I just need a muffler Arteest that will rise to the challenge.
Have you looked at SpinTech's website? They offer oval tubing and transitions. Perhaps they have stock pieces that you can adapt?
