Car wont start
Tekira
Hi, Well just after i get my 40mm mikunis on my 260z installed i go to crank the engine and it turns but wont fire. So i try to stay calm and i figured i would check to see if fuel was getting pumped through the lines. i disconnect the fuel line at the metal fuel line at the engine and turn on the ign. No fuel at all was comming out of the line. Is there a fuse in the fuse box that controls the fuel pump or would cause it not to work. crap iam so mad. I am pretty sure the fuel pump is allright. its was installed in 98. So i am pretty sure this is eletrical.
Thx,
Josh.
Well well well... I love it when mechanic shops rip you off. When i took my car in for a rebuild in 1998 on the parts list was "New Eletric pump----85.95" I guess they didnt think i would try to eleminate the mechanical pump at the front for triple carbs. Like i said the carwouldnt start so i go to check the eletrical fuel pump AND IT WASN'T EVEN CONNECTED!. It gets better..... Ok no prob right just connect the fuel lines...NO... It was the ORIGINAL FUEL PUMP! Not the "New" one they said they installed and charged me for. Well anywho i hooked up the fuel lines to the eletric and still no gas. the wires at the pump are connected, But where do the wires go to so i can make sure they are connected to the body harness. Thats my main question.
Thx,
Josh.
