Need help with seatbelts???
I am wanting to use Miata seats in my 73. I have an 8 pt roll cage welded in and can no longer use my three point seat belts in the standard location. Are there 4 pt seat belts that will work on a high back seat with no through holes? Also, is there an easy way to go back with a three point? I really want to be able to use the Miata seats for clearance and $ reasons. Please help me out here.
I know this is not the right forum for this but I couldnt really find one that it fit in.
Guest 240Z_72
I'll take a shot at this, since nobody else is. I had trouble with both my '72 and '76. Once the seats were swapped, or a cage installed, I couldn't use the stock belts/locations. It just took a little experimentation. I reversed the lap belt, and removed the shoulder strap for a while. Tried other belt combo's. Finally ended up with a set of 3" racing harnesses. 3 or 4 point setup. If your miata seats are narrow enough at the top, then you can probably find something to work. Find a good spot behind you on the cage to weld a mount point for the harness.
