grumpyvette Posted October 11, 2002 Share Posted October 11, 2002 for some reason my EMAIL has not been able to send for the last few weeks only receive niceguy678us you asked about a good combo that will get into the high 450-475 plus hp range heres a combo that will get you what you want with a manual trans, Id suggest 4.11 rear gears 406 chevy small block 10.5/1 cpr 6" rods 195cc AIR FLOW RESEARCH HEADS edelbrock super victor intake 750-800 cfm carb 1 3/4" full length headers cam, http://www.compcams.com/information/search/CamDetails.asp?PartNumber=12-433-8 now carbs are easier to work with than EFI for new guys so thats why its a carb setup you can get better mileage and similar power useing this holley system/intake if you chose EFI 550-650 1000 4-bbl square flange 36 lbs./hr. 91005201 91005301 http://www.holley.com/HiOctn/ProdLine/Products/C950/FuelInj_pics/98-400.jpg http://www.holley.com/HiOctn/ProdLine/Products/C950/C950MPFI/MPFIS.html#1 this fits under the hood better than the steath ram and tuned properly makes more than enough power to reach your goal plus its laptop tuneable, either way you go youll reach your goal of a killer street/racing engine that remains at least reasonably streetable but has great power Quote Link to comment Share on other sites More sharing options...
niceguy678us Posted October 11, 2002 Share Posted October 11, 2002 wouldn't 4:11 gears be too much? I thought the light weight Z didn't have hardly any traction through the first two gears anyway with a built up motor? Wouldn't something around 3:54 be a better choice? and as always, your wisdom and advice are greatly appreciated you are the man Quote Link to comment Share on other sites More sharing options...
niceguy678us Posted October 11, 2002 Share Posted October 11, 2002 my ex-daily driver was a 75 2+2 and I loved to stay between 100, and 120 when possible. I know this is not safe , but I'm young and dumb and enjoying the hell out of it. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted October 12, 2002 Author Share Posted October 12, 2002 the 3.54 gears will be fine and give you a higher top speed but they will also cost you slightly if your useing slicks and drag racing Quote Link to comment Share on other sites More sharing options...
