Guest jjohart Posted March 30, 2004 Share Posted March 30, 2004 Hi, I've tried white lithium grease, mechanic's grease spray and WD40, and after a few days, all of these wear off so that I hear a chirp from somewhere in the hood latch. The spraying works perfectly for stopping it, and it is not the hood bouncing that makes this chirp, yet I can't find anything loose in the hood mechanisms, latch and wire. It used to drive me crazy thinking it was something under the dash, and I sprayed everywhere, to no avail, until I discovered it by driving around with the hood unlocked. I wish someone could tell me what part to replace...has anyone heard this kind of thing? What kind of spray or oil will keep it's lubrication, so I don't have to open the hood and spray it every few days!?!!? Thanks John-83 280ZXT Quote Link to comment Share on other sites More sharing options...
Guest Aaron Posted March 30, 2004 Share Posted March 30, 2004 Quick fix: Remove your muffler. You won't here the squeek anymore. Quote Link to comment Share on other sites More sharing options...
Phantom Posted March 30, 2004 Share Posted March 30, 2004 John, There are two rubber covered "buttons - one at each trailing corner of your hood that ensure that it is properly supported at each of those corners. If one or both are down a little the hood can move around or even 'flutter' a bit. If you adjust them up they will put a little tension on the latch which will eliminate movement and also encourage the hood to 'spring' up a bit when you pull the hood release. That might also eliminate your squeak. Quote Link to comment Share on other sites More sharing options...
