Guest kc280zx Posted March 30, 2004 Share Posted March 30, 2004 ive got a stock bottom end, ported gt40s from a 95 cobra, ford e cam, victor jr carb intake, and dont have carb yet. i will probably run a 650 carb, but not sure yet. for now i will have a stock T-5 in it, but im already saving my pennies for a Lentech AOD as an upgrade. Only reason for the Lentech AOD is the 100 shot im going to run after i get the tranny b/c i dont want to blow my T-5 and not be able to drive lol. i am hoping to keep some street drivability with this thing. i just wanna be able to pull up next to a Z06 vette and actually hang or hell even beat em. ive already got the suspension on to handle the twisties, now i just need the go fast for the striaghts. another motivation for me to build this car up is: 1 i havent seen any 280zx's with a SBF 2 both of my roommates drive supercharged mustangs putting out 500hp 3 im tired of losing, but dont wanna sell out to the mustang Quote Link to comment Share on other sites More sharing options...
KRAYZ Posted March 30, 2004 Share Posted March 30, 2004 Not that i can recall reading,however your intake outflows your heads.You may want to look into a performer rpm,or if you really are stuck on a singleplane intake try the torker2 or wieand xcelerator with smaller intake ports.There are several build ups that would get you very close to 330hp. with those heads and a intake other than the victor jr. ,the E cam and your heads(ported) with about 625-750cfm carb. that depends on the intake you use and where you want to make your power the RPM intake will give you more tq.early with a smaller carb(625-650).The torker2 will give you more mid range to top end pull(700-750)carb. but both will depend on what your rear gearing is going to be....But this is all just bench building w/o actual head flow ## or carb jetting Quote Link to comment Share on other sites More sharing options...
Guest kc280zx Posted April 6, 2004 Share Posted April 6, 2004 i just bought my dad's 5.0 stang after a year and half of constant nagging. since i was wanting my z to be fast in the straights, i will just make the mustang fast since thats what it was designed to do. thanks for yall's support. later Z Quote Link to comment Share on other sites More sharing options...
Guest stickaz Posted April 20, 2004 Share Posted April 20, 2004 I'm thinking you'll need some N20 to hang with a Viper. Why? Let's say you're 2800#'s w/driver (assumptions, 240z=2400 lbs, 302 conversion added 200#'s over the I6 and you weigh 200), I'm guessing that mildly mis-matched 302 makes 280 to the wheels, not bad. With traction, should run 110-112 in the 1/4 (trap), now let's take a Z06. Those weigh in around 3250#'s w/driver, and make around 350 to the wheels stock. Ouch. They seem to trap around 115-116 stock depending on weather/etc. So you'll get pulled. Basically you need another 40 rwhp or so, which given that you're choosing a carb'd 302 can come from +better cam +more appropriate intake +compression (milling?) and a proper build (port-matched heads to intake, properly adjusted rockers, etc. all) Quote Link to comment Share on other sites More sharing options...
