280Zen Posted April 5, 2004 Share Posted April 5, 2004 Ok, Who can tell me how to determine what injectors are what O ring size? I've been reading and most websites will tell me everything I need to know except what size the O ring OD is. Quote Link to comment Share on other sites More sharing options...
Guest verybad1 Posted April 23, 2004 Share Posted April 23, 2004 There are lots of sizes, I have over 100 different sizes and still building my stock. For which injector are you wanting the info? Gordon WitchHunter Performance http://www.witchhunter.com Quote Link to comment Share on other sites More sharing options...
280Zen Posted April 23, 2004 Author Share Posted April 23, 2004 Ok, how about a low impediance injector, 21lb with a 10mm OD Oring. I'll need six of them for my superchared L28 Quote Link to comment Share on other sites More sharing options...
Tim240z Posted April 23, 2004 Share Posted April 23, 2004 There are lots of sizes' date=' I have over 100 different sizes and still building my stock. For which injector are you wanting the info? Gordon WitchHunter Performance http://www.witchhunter.com[/quote'] Hi Gordon, welcome to the boards!! How about setting some special member discounts for the HybridZ guys? I'm sure that we can throw some business your way. It's gonna be nice to have an injector specialist providing knowledge to all of us too!!! Tim Quote Link to comment Share on other sites More sharing options...
Guest verybad1 Posted April 25, 2004 Share Posted April 25, 2004 Ok, how about a low impediance injector, 21lb with a 10mm OD Oring. I'll need six of them for my superchared L28 Do you have an injector number? If not, more hints are needed; Injector manufacurer ? Top feed or side feed? Upper or lower O-rings? Aprox o-ring thickness and ID. Even the color can help sometimes. Really hate to guess. There are so many sizes that are so close to each other that I insist the people always send the orings with the injectors to be serviced. Hate to send the units back with the wrong one's. Gordon http://www.witchhunter.com[/url] Quote Link to comment Share on other sites More sharing options...
280Zen Posted April 25, 2004 Author Share Posted April 25, 2004 Do you have an injector number? If not, more hints are needed; Injector manufacurer ? Top feed or side feed? Upper or lower O-rings? Aprox o-ring thickness and ID. Even the color can help sometimes I don't have injectors; I don't care who makes them Top feed I have a fuel rail thats drilled to accept 10mm press fit Oring injectors 10MM again Im looking to buy so I don't have any. I picked up a fuel rail off Ebay sometime ago that was drilled to accept 10mm Oring Injectors for a 280zx application, Im simply looking for a set of injectors that will fit this fuel rail. Thats the issue, Nobody lists the O ring size just the car is designed for and the LB rating. Quote Link to comment Share on other sites More sharing options...
Guest verybad1 Posted April 26, 2004 Share Posted April 26, 2004 There are lots of sizes' date=' I have over 100 different sizes and still building my stock. For which injector are you wanting the info? Gordon WitchHunter Performance http://www.witchhunter.com[/quote'] Hi Gordon, welcome to the boards!! How about setting some special member discounts for the HybridZ guys? I'm sure that we can throw some business your way. It's gonna be nice to have an injector specialist providing knowledge to all of us too!!! Tim Thanks Tim, I saw some traffic coming from this board and thought I'd take a look and see what you guys were up to. I can give the HybridZ guys a 10% discount on Cleaning and Flow testing on 6 or more injectors from now until July 4th. Just let me know (remind) me when you send them. I only charge $12 each normaly, so that doesn't leave too much to play with. Gordon WitchHunter Performance http://www.witchhunter.com Quote Link to comment Share on other sites More sharing options...
