New Megasquirt Fuel Map - Wideband Tuned
sims76
For those of you that run megasquirt, here is my updated Megatune *.msq
file that I just finished tuning with my new PLX Wideband. I was constantly making adjustments last year without the wideband and never got it right. I was running 15+ air/fuel ratio at 4500 RPS's and up. Not good. This map is pretty good, 13's at full throttle and 14's everywhere else. It's for a non-turbo L28.
Here is the linky to the Yahoo board where I uploaded the settings:
http://f3.grp.yahoofs.com/v1/oNWFQAWw3pgFgZPWmOS4wK4z9HSj2do-T15GeQ7OpRwE39NlXL9P7bKS4zbuBxJk9_Gr7TDpgZs52vo5fipGdOANJvI/Megatune%20settings/Datsun_280z_nonturbo_19lb_injectors.msq
EVEME 1.0
UserRev: 1.00
UserComment:
Date: 04-20-2004
Time: 22:26
Page 0
VE Table RPM Range [ 8]
[ 0] = 5
[ 1] = 10
[ 2] = 20
[ 3] = 30
[ 4] = 37
[ 5] = 45
[ 6] = 55
[ 7] = 65
VE Table Load Range (MAP) [ 8]
[ 0] = 20
[ 1] = 30
[ 2] = 50
[ 3] = 65
[ 4] = 82
[ 5] = 90
[ 6] = 95
[ 7] = 100
VE Table [ 8][ 8]
[ 0] [ 1] [ 2] [ 3] [ 4] [ 5] [ 6] [ 7]
[ 0] = 52 58 60 57 52 52 41 41
[ 1] = 55 56 68 69 64 61 68 70
[ 2] = 52 56 59 69 81 86 85 79
[ 3] = 57 57 60 82 96 99 96 96
[ 4] = 60 58 72 88 96 95 103 103
[ 5] = 64 79 83 93 105 109 109 109
[ 6] = 70 88 98 108 112 127 125 113
[ 7] = 70 88 102 107 121 134 136 125
I'm going to have the track car on the dyno next month, so I'll bring your map along and try it.
Here is the engine config:
10:1 L28, stock bore
Stock N47 head and cam
6:1 header 2.5" exhaust with 3" supertrapp.
60mm TB
19lb injectors
Pete
  • 1 year later...
Hi there!
This is my first post on this forum.
I've got an L28 with similar modifications like you:
-Stock engine and injectors
-6 to 1 header, 2.5" exhaust
-60 mm throttle body
-Some sort of cam with higher lift..
-MS 3.0 (2.25) and MSnS-E for sparks.
Also planning to use an EDIS6 which I'm installing these days.
If things go like I've planned, the engine will be started up in a couple of weeks.
So a map would be very helpful. :) BTW Sim76, it does'nt seem like your link in the first post is working... ?
Thanks
Jørgen, 70 240Z
I'm going to have the track car on the dyno next month' date=' so I'll bring your map along and try it.
60mm TB
19lb injectors
Pete[/quote']
Question: How are you running 10:1 compression, on stock bore and stock N47 head? Are you running a stroker crank somehow?
Welcome to the boards RedHotZ.:-D
