Clutch Fork Clearance
74.5 347Z
For those of you that have installed your push/pull slave cylinders, does your clutch fork have enough clearance? My clutch fork doesn't clear the trans tunnel and I was wondering if this is a common problem.
Just for information purposes, I have a '87 5.0 (347 stroker kit, I have to add), WC T-5, and a GT-40 intake which caused me to have to mount my engine lower and further back. This has caused me to considered using a hyd throwout bearing like Terry's set up. Has anyone priced one of those lately?
Any help would be greatly appreciated.
Mark
If the engine/trans position is correctly lined-up with the diff, then consider the clearancing part of the norm as far as an engine swap is concerned. In fact anything that doesn't weaken structural integrity is fair game to bend, bash-in or cut-off.
If you want to be really cool, cut out the area that you need to clearance, fab-up a little sheet metal cover and weld it over the hole. Nice and neat, looks professional.
And yes, it is normal.
Should kick ass with that 347.
jon
Considering the $75 difference in the two setups and the holes drilled in the bellhousing' date=' I will go with the ballpeen method.
Does everyone have this problem or is it because of the position of my engine/trans?[/quote']
Must be your mounting position. Mine doesn't hit.
