Toysport Posted April 23, 2004 Share Posted April 23, 2004 hi guys......i picked up a sbc last night in buena park, california. it's free, the giver said that this engine is there when she moved in and that her son in-law told her that its a chevy but not sure whether it's a 305 or 350. on the engine block number reads gm3970010. how can i......or where to go to determine what's not. any help is greatly appreciated. -thanks- Quote Link to comment Share on other sites More sharing options...
Tim240z Posted April 23, 2004 Share Posted April 23, 2004 It could be: 1. 350 from 69 to 80. Could be either 2 bolt or 4 bolt mains. Drop the pan to see. 2. 302 from a 69 Z28 4 bolt 3. 327 truck engine Free is good!! Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted April 23, 2004 Share Posted April 23, 2004 It would be great if it was a 302!!!! Tim240Z is right and here is the place where you can find casting numbers http://www.mortec.com/castnum.htm Quote Link to comment Share on other sites More sharing options...
dsommer Posted April 23, 2004 Share Posted April 23, 2004 Seems that it might be a 302 w/4bolt mains!!! Wow that puppy could be worth some $$$ if it's rebuildable. What you should do is try to find the car the engine originally came out of. Drop me a PM and I'll get you in touch with sombody that know's 1gen Camaros like the back of his hand. If the car is on a historic registry then you may be able to contact the owner, who in turn could have his numbers matching car again, for a price David Quote Link to comment Share on other sites More sharing options...
Toysport Posted April 23, 2004 Author Share Posted April 23, 2004 okay.....its a 74-76 350 sbc......v/y code Quote Link to comment Share on other sites More sharing options...
Toysport Posted April 23, 2004 Author Share Posted April 23, 2004 Seems that it might be a 302 w/4bolt mains!!! Wow that puppy could be worth some $$$ if it's rebuildable. What you should do is try to find the car the engine originally came out of. Drop me a PM and I'll get you in touch with sombody that know's 1gen Camaros like the back of his hand. If the car is on a historic registry then you may be able to contact the owner' date=' who in turn could have his numbers matching car again, for a price David[/quote'] .......what's so special about the 302? just curious. Quote Link to comment Share on other sites More sharing options...
baddriver Posted April 23, 2004 Share Posted April 23, 2004 The 302 is special cause it was the original z28 motor from 68 and 69. It's a very rare and desireable motor with a 4" bore and short stroke. The large bore allows it to use large valve heads and I believe it was also a high compression solid cam motor. Not to be confused with the 307, which had a small bore and long stroke, came only in 2bbl configuration (I've never seen a 4bbl, but I don't know for sure they don't exist) which was a pretty wimpy, but reliable motor. Also not to be confused with the modern 305, which also has a smaller bore than a 350 but apperently differs from the 307 in some manner, about which I am not clear. I'm sure a dozen people in here could school me as to why. Anyway, congrats on the free motor. While a 302 would have been a great find, you'll be able to rebuild a 350 for less and get more power out of it. Quote Link to comment Share on other sites More sharing options...
Toysport Posted April 24, 2004 Author Share Posted April 24, 2004 thanks.....click the links for pix. http://supra-sport.com/350_engine1.JPG http://supra-sport.com/350_engine2.JPG http://supra-sport.com/350_engine3.JPG http://supra-sport.com/350_engine4.JPG Quote Link to comment Share on other sites More sharing options...
Toysport Posted April 24, 2004 Author Share Posted April 24, 2004 okay....here's what i have discovered so far on my csb engine. Head Casting #: 3986339X (1971 307 or 350 74cc chambers) Block Casting #: GM3970010 (1971 307 or 350 - 2 or 4 bolt) Block Casting Date: H 26 1 (H=August, 26= the 26th day of the month and 1 stands for 1971) 302: built 1969 4 bolt z28 camaro 327: built 1969 2 bolt trucks and industrial 350: built 69-80 2 or 4 bolt all three shares the same block casting number my csb engine is definitely a 350 2 or 4 bolt.....correct me if i'm wrong. question: how will i know if it is a 2 or 4 bolt? feedback...... Quote Link to comment Share on other sites More sharing options...
Guest GPSMatt Posted April 24, 2004 Share Posted April 24, 2004 Drop the pan and you will see. Quote Link to comment Share on other sites More sharing options...
Toysport Posted April 24, 2004 Author Share Posted April 24, 2004 i dropped the pan today matt and this is how it looks. how can i tell if its a 2 or 4 bolt. -thanks- john Quote Link to comment Share on other sites More sharing options...
Tim240z Posted April 24, 2004 Share Posted April 24, 2004 2 bolt mains What you are looking at are the # of bolts that hold the caps in place which hold the crank in place. You have two per cap, some have 4. Tim Quote Link to comment Share on other sites More sharing options...
Toysport Posted April 24, 2004 Author Share Posted April 24, 2004 tim.....correct me if i'm wrong.....there are five caps right? if so, there are two bolts per cap. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted April 24, 2004 Share Posted April 24, 2004 You are correct. The front and rear ones will always be two bolt...the three center ones can be 2 or 4.... Tim Quote Link to comment Share on other sites More sharing options...
Toysport Posted April 24, 2004 Author Share Posted April 24, 2004 cool man........all my caps have 2 bolts. so this is what i got..........1971 chevy 350 small block 2 bolts main. what is the stock hp in this baby. thanks tim. john Quote Link to comment Share on other sites More sharing options...
Tim240z Posted April 24, 2004 Share Posted April 24, 2004 AND....you have '10' block (look at the last two numbers of the casting number), which means it's the high nickel block, which were/are proported to be much stronger than the newer ones... HP=likely not much....but you have a good platform to start with... Tim Quote Link to comment Share on other sites More sharing options...
Toysport Posted April 24, 2004 Author Share Posted April 24, 2004 thanks man........today i removed everything and the only the block remains on the stand. http://supra-sport.com/350_engine5.JPG http://supra-sport.com/350_engine6.JPG http://supra-sport.com/350_engine7.JPG http://supra-sport.com/350_engine8.JPG http://supra-sport.com/350_engine9.JPG http://supra-sport.com/350_engine10.JPG http://supra-sport.com/350_engine11.JPG feedbacks........ Quote Link to comment Share on other sites More sharing options...
