push button T/S self canceling switches
Guest 305240
Guest 305240
I came across this web site while searching for alternative turn signal switches. Has anyone ever tried something like this? I'm in the process of completely rewiring my car. Mainly because I don't have much wiring left. I've already decided to go with the push button starter/ignition system, and manual circuit breakers, along with the LED lights.
http://www.watsons-streetworks.com/switches.html
scroll down to see the T/S switches
Guest 305240
I'm using the stock column. Without any of the switches, it's nice and clean. I just have to fab a cover of sorts to fill in the space on each side of the column.
Guest 305240
I'll be using the stock spedo, but the rest will prolly be autometer. I'll use the small LED for my brights. I'm going to use a two position rocker switch for my bright/dims. I found another site where the push buttons actually light up when they are on. Seeing as my heater control panel is missing and part of my console, I will have to fab the lower center of the dash. and I prolly make a new custom console that will house/hide most of my switches.
