chassirack?
i see that alot of guys are making rotisseries to get the car on the side. I was planning on doing the same thing but then i saw the pictures of this guys golf gti. it seems to be alot easier to make and does the same thing. its also alot easier to move on a trailer. has anyone done this on a z? i was thinking of connecting it on the attachmentpoints for the front suspension and at the bumpermounts at the back. does this seem like a good idea?
That's not a bad idea. The thing I don't like about most rotisseries it the large mounts you need to weld to the front and rear of the car. This would keep the mounts on the underside of the car where it is stronger. With such a design you could also replace front frame rails without worring about the car buckling on you.
One obvious and potentially fatal flaw is it will take more shop space and a couple of strong friends to safely put on it's side.
