Guest dmk2123 Posted May 4, 2004 Share Posted May 4, 2004 Can I get 235/45/17 on a 17x7.5 wheel in the back without rubbing? I'll be putting 225/45/16 on 16x7 on the front, those should be good right? Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted May 4, 2004 Share Posted May 4, 2004 I'm running 225/45/16's all the way around on my 81 turbo. No sweat on the fronts, but the back may get a little close. I don't have much room left on mine. So far I havn't noticed any rubbing or bottoming out. The ride is a little stiffer tho. Quote Link to comment Share on other sites More sharing options...
2126 Posted May 4, 2004 Share Posted May 4, 2004 Dave, You should have no problem with your choice if you select a wheel with the correct offset/backspacing. I've got 235-40x17 in the rear of my 1970, however they are on 9" wide wheels, with sectioned struts and coilovers. Quote Link to comment Share on other sites More sharing options...
