Guest Chevelle7d2 Posted May 14, 2004 Share Posted May 14, 2004 So I ran across this web site http://www.speartech.com/coproj-1991ls1.html and got to thinking, why couldnt I do this with my 84 300ZX?? Although I havent test fitted my LS1 or anything yet in my engine bay, Does anyone think that this way of mounting the motor and making custom brackets would work? It seems like it would, but agian, the clearance and everything may not be the same... Just a thought. What do you guys think? Quote Link to comment Share on other sites More sharing options...
80LS1T Posted May 14, 2004 Share Posted May 14, 2004 If the crossmember in the 300ZX is in the right position I would think it would work just fine. But is the crossmember right where it needs to be......or is it too far forward or too far rearward? You will have to test fit it to find out for sure. Your in uncharted/undocumented territory so you will just have to learn as you go. I dont think Ive seen an LS1 in a 84-98 300ZX. Good luck! Guy Quote Link to comment Share on other sites More sharing options...
Guest Chevelle7d2 Posted May 14, 2004 Share Posted May 14, 2004 Welp looks like Im the genie pig... Im hoping to have it done by the end of the summer! Quote Link to comment Share on other sites More sharing options...
jeromio Posted May 14, 2004 Share Posted May 14, 2004 ls1tech.com/forums/forumdisplay.php?f=28 YOu will very likely end up needing a Holden oil pan. This can be purchased from Sean at SMC: valvegod at aol dot com. Quote Link to comment Share on other sites More sharing options...
Guest Chevelle7d2 Posted May 15, 2004 Share Posted May 15, 2004 Anyone know if the crossmember in a 240 is the same (or close) to the same as the crossmember found in a 300?? IF so then I will deffinately most likely need a Holden oil pan. Anyone? Quote Link to comment Share on other sites More sharing options...
