evildky Posted May 14, 2004 Share Posted May 14, 2004 so I had a hella sweet smokey second gear burn out a while back and duplicating it has been difficult, trying to just from clutch to brake before it grabs and after it starts to spool, a line lock would make this a bit easier surely many of your drag racers have installed one so here is my question,will one seleniod before the proportioning valve work? it just seems to me the proportioning valve will allow some pressure off the front and apply it to the rears? no? or do I need to put one on each front brake line? this is an early 71 model, so I only have the one piece proportioning valve/distribution block who is using line locks and how did you run yours? Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted May 14, 2004 Share Posted May 14, 2004 This should help: http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=18792&highlight=linelock Quote Link to comment Share on other sites More sharing options...
