grumpyvette Posted November 11, 2002 Share Posted November 11, 2002 some good general info here look closely at the duration used for each MATCHING rpm range. ALSO KEEP IN MIND THE DCR AND OVERLAP MUST MATCH look here these are the valve timeing overlap ranges that are most likely to work correctly trucks/good mileage towing 10-35 degs overlap daily driven low rpm performance 30-55degs overlap hot street performance 50-75 degs overlap oval track racing 70-95degs overlap dragster/comp eliminator engines 90-115 degs overlap but all engines will need the correct matching dcr for those overlap figures to correctly scavage the cylinders in the rpm ranges that apply to each engines use range. http://cochise.uia.net/pkelley2/Overlap.html http://cochise.uia.net/pkelley2/DynamicCR.html and keep in mind lower overlap duration and LSAs of 112-115 work better with EFI and I can tell you right now that intake durations not to exceed about 222 degs@.050 (intake duration)are what youll need for a close to stock TPI intakes rpm/tq range now just to make you crazy, don,t forget that the longer your rods are (closer to the ideal 2:1 rod to stroke ratio) the wider the lsa should be and the longer the stroke the wider the lsa should be http://www.compcams.com/Base/Images/Articles/CC_CC0101-001-2.jpg[/img] 1985,1992,1996 vettes keep the rubber side down and the Quote Link to comment Share on other sites More sharing options...
Guest the_dj Posted November 11, 2002 Share Posted November 11, 2002 Now you've gone and made me question my cam choice. Thanks for the info though Quote Link to comment Share on other sites More sharing options...
