build your own custom windage screen
heres an option
http://victorylibrary.com/mopar/baffle.htm
BTW ,IF I built a pan like that ID BRAZE the bolts to the pan to seal the potential oil leak points and to make sure no parts came loose but I would also design the screen as a removable center section by having its edges fit into a small channel bolted and brazed to each side of the oil pan, so that it was bent to snap into place and sprung back into the channels durring use, and use a few cross braces carefully centered under the main caps to keep it ridgid
