Guest xbangu Posted May 24, 2004 Share Posted May 24, 2004 I am converting my 240Z into a L28et, I am almost done... when I tyr to start the car won't start and I notice that there are no fuel coming out. My fuel pump working, I think?.. I heard the fuel pump pump for about 5-8 sec. when the ign is ON and then stop... Also because I cleanout the fuel tank with allnew hoses prior to starting it up and right now I have about 7 gallon in my tank right now. Do I need the fuel tank to build up enought pressure, before fuel can come out??? Can anyone helpme out, appreciates thanks xbangu Quote Link to comment Share on other sites More sharing options...
evildky Posted May 24, 2004 Share Posted May 24, 2004 check your afm connectors, I still don't understand why but if it's stuck it'll shut the pump off after a few seconds go get an inline fuel pressure guage and hook it up and you'll be supized just how great of an investment it is, I am planning on adding one for the interior as well Quote Link to comment Share on other sites More sharing options...
Guest xbangu Posted May 24, 2004 Share Posted May 24, 2004 Ok, I'll check the amf,.... and to make it clear this is my firs time tryign to start my car and there is NO, not a single drop of gas coming out from the fuel pump. Could I hook up the pump in/out back ward??? also I thought the fuel pump suppose to pump for about 5 sec when the ign is onthe "ON" position.. I'll try to work on more tomorrow.. thanks for the feedback Evil. Quote Link to comment Share on other sites More sharing options...
Guest xbangu Posted May 25, 2004 Share Posted May 25, 2004 the car started now... it turned out that when you empty the tank and clean it out.. and when you put it all back together, you need an initial flow to the fuel pump to get the fuel pumped out. Quote Link to comment Share on other sites More sharing options...
