namz7791 Posted May 25, 2004 Share Posted May 25, 2004 In the JTR manual it says to use a dampner that is 7.25" or less in diameter so I installed a 6.75" dampner; so far so good. I was getting ready to install my original pulley which is the one used in a 88 suburban and it is a bigger diameter than the dampner maybe 8" or so. JTR doesn't cover the pulley sizes so I am wondering if any of you guys had to get different pulley for your dampner or does it stick out passsed the steering far enough with the JTR kit so it is ok to use? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
Guest 77vegasz Posted May 25, 2004 Share Posted May 25, 2004 Go to http://www.jegs.com, or http://www.summitracing.com. Both sites sell all types of pulleys, v-belt, serpentine drive, underdrive, etc. I run a short water pump with an underdrive pulley set up that fits nicely and does the job. I also run a 6.75 damper. Jon Quote Link to comment Share on other sites More sharing options...
