shauno Posted May 27, 2004 Share Posted May 27, 2004 I'm in search of a vaccum pump from some other car, doesn't matter what make, to give my brakes a better feel. At the moment I can't even lock them up due to my low manifold pressure 10 in/hg and my large master size 300zxtt. I don't really want to change the master and I don't think a cannister will work for me cuz I just need more vacuum not volume. Has anyone used such a thing, other than the expensive units from summit? Or maybe some insight? Like I said, the master is a 300zxtt and the booster is stock 72. the front calipers are newer toyotas and the rear are 240sx. I have a proportioning valve installed and I've eliminated the stock regulator. Please help, many thanks. Quote Link to comment Share on other sites More sharing options...
z-ya Posted May 27, 2004 Share Posted May 27, 2004 A freind of mine was having the same problem with his brakes, and put in a vaccum canister. It worked great, he can lock them up no problem now. He is running a 300HP Rebello 3.2L, so the cam is fairly agressive. Pete Quote Link to comment Share on other sites More sharing options...
V8ZRACER260Z Posted May 27, 2004 Share Posted May 27, 2004 Same with me I have a Comp Cams vaccum canister on my V8 with no problems. That's the way to go. Rick Quote Link to comment Share on other sites More sharing options...
srgunz Posted May 29, 2004 Share Posted May 29, 2004 Have you set the correct clearence between the booster pushrod and the mastercylinder piston? You will not lock up any brakes if that gap is too great. Quote Link to comment Share on other sites More sharing options...
