Cjarloz Posted June 3, 2004 Share Posted June 3, 2004 Ok guys i have been searching and i can't seem to find what year 240sx Tb i am supposed to be looking for for my turbo l28 swap help me out. Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted June 4, 2004 Share Posted June 4, 2004 you are looking for one with the single cam KA24E. It should be in 88's and 89's. The ones without cruise control are the best ones to get, you dont have to do any cutting, threading, or any other tricky mods. Quote Link to comment Share on other sites More sharing options...
Jersey Posted June 4, 2004 Share Posted June 4, 2004 I have an extra 60mm TB that i was going to put up on ebay if your interested. I received two at one time and this one has a Potentiometer type TPS on it and since i decided to stay with stock ECU for now, i'm going to use the other that has the open/close type TPS. If your going to use aftermarket electronics, i believe you could use this just as it is. Otherwise, you'd have to swap it out with an open/close type TPS that the stock ZXT ECU needs to see. It is a Nissan unit, not Hitachi, non cruise control and i belive it's from a '89 240sx. That's what i was told anyway when i bought it. Just a thought. I'll post a pic, even if it's just for reference so you know what to look for. Good luck. Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted June 4, 2004 Share Posted June 4, 2004 That one is from an SR20 (nx2000, sentra SER) The TPS will work, Im running one on my car right now. the onlything that may be odd about that throttle body is the shaft size. You would have to dremel out the stock linkage to the propper size to make it fit over the shaft. Quote Link to comment Share on other sites More sharing options...
Jersey Posted June 4, 2004 Share Posted June 4, 2004 Thanks for the clarification on what it came off of Kenny. I didn't get any open/close between any two contacts, just different values at different throttle positions on two of the pins. I guess the resistance value at rest is so low (something like .2k ohms) the stock ECU reads this as a close. The stock Z linkage does fit on this one. I just went outside and double-checked, swapped linkages and took a pic. Guess i should just leave it like this... Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted June 4, 2004 Share Posted June 4, 2004 I usually get around $60 for those on Ebay. I sell the throttle bodies already modded when I find the 240sx ones at the JY. Quote Link to comment Share on other sites More sharing options...
Cjarloz Posted June 4, 2004 Author Share Posted June 4, 2004 thx guys now to the junkyard lol. umless some one can give me one cheap. i will be using the stock zxt ecu also for now. Quote Link to comment Share on other sites More sharing options...
