engine setup, lookover and advise
Guest polarity
Guest polarity
Vortec heads
Performer intake
Crane Powermax #114142 camshaft, 216, 228 @.050 - 112 LSA
Edelbrock Performer manifold
Holley 650
block bored .30
now one more question, what type of pistons should i use. I've read lots of stuff on this site about them. hypertech's any good? (grumpy if you have anything on pistons I would very much appreciate it)
Billy
Check the valve lift of that cam. Stock vortec heads are limited to around .450"? of valve lift. Not sure of the exact number. Scoggin Dickey Chevrolet sells vortec heads that I think have had the valve guides machined to allow for more valve lift. I just wanted to make you aware in case you did not not know that this could be a potential problem.
http://www.sdpc2000.com/cart.asp?action=catalog_start&catid=2172
Danny
Guest polarity
wow, that seems pretty cheap. The place in town I'm was looking to buy my heads from wanted $1500 for JUST the heads. That has gaskets, heads, intake, everything for like $800.
to get the correct quench distance the head gasket should be about .020 or less thick, that thin gasket and the vortec heads 64cc combustion chamber will require a piston with about a 18cc-22cc negative dome size like this one
KB142 your dynamic compression will be ok with this piston for high test and KB101this piston for regular with that cam
http://www.kb-silvolite.com/page25.htm
to run pump gas.
the guys are correct that you might need the upgraded heads to run that .480 exhaust lift cam (a very good idea to get them anyway) as the stock vortec heads can,t handle a .480 lift sometimes (clearance problems)
http://www.kb-silvolite.com/page05.htm
http://www.kb-silvolite.com/speclear.htm#CHART
http://Parts@sallee-chevrolet.com/Cylinder_Heads/Vortec.html
hypereutectic pistons are fine at that hp level
