Guest Pegasus76 Posted June 5, 2004 Share Posted June 5, 2004 Ok, here's the deal. I just got done switching ou the spark plugs and the wires...But now it sounds OFF It starts and it runs but neither the engine or the exhaust seem to sound smooth while running. Before I changed the plugs and the wires I was idling at 8 and 9...Now I'm running at 5 and 6...Any advice on what happened and what to do? Quote Link to comment Share on other sites More sharing options...
Guest Pegasus76 Posted June 6, 2004 Share Posted June 6, 2004 By the way, I have an 86 300ZX Quote Link to comment Share on other sites More sharing options...
Tim240z Posted June 6, 2004 Share Posted June 6, 2004 Recheck your firing order... Quote Link to comment Share on other sites More sharing options...
Phyte Posted June 6, 2004 Share Posted June 6, 2004 Firing order like Tim said, also did you gap your plugs? Phyte Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted June 6, 2004 Share Posted June 6, 2004 yeah you probably put them on in the wrong order, or the gaps arent right, or at worst you got defective parts... all easily tested and checked. Quote Link to comment Share on other sites More sharing options...
Guest Pegasus76 Posted June 6, 2004 Share Posted June 6, 2004 Hmmmm arne't the plugs supposed to be at .43? Also, what is the correct firing order? I could of sworn I put them in right, but just to make sure...Is there a site or can someone tell me? Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted June 6, 2004 Share Posted June 6, 2004 ugh... you dont have a haynes manual or something similiar? Did you take the wires off and replace them one at a time so as not to mix the order up? I dont have the manual for 300zx so not sure on the order on that... it's always good to have a haynes manual for whatever car you own, if you do any work on the car yourself or even if you dont, it's a good way sometimes to figure out what might be wrong with your car. I say pick one up ASAP Quote Link to comment Share on other sites More sharing options...
Guest Pegasus76 Posted June 6, 2004 Share Posted June 6, 2004 I had one a while ago, but I gave it to my friend when I sold my last 300ZX Quote Link to comment Share on other sites More sharing options...
Guest Pegasus76 Posted June 6, 2004 Share Posted June 6, 2004 I got it fixed guys...I accidently switched 3 and 5...I did the wiring one by one but I guess I slipped up Sorry for the amateur quesiton Quote Link to comment Share on other sites More sharing options...
