383LT1
Guest Chevelle7d2
Guest Chevelle7d2
I found a 383 LT1 that has the following done to it:
-1994 T/A block
-Eagle 4340 forged 3.75" crank
-Eagle forged 6" H-beam rods
-SRP forged flat top pistons (10.6:1 compression ratio)
-heads were done by a local machine shop like a stage 2 setup (mild port/bowl work oversize valves)
-CC305 cam, 220/230 duration @.050, .510/.510 lift (.544/.544 w/ 1.6 rockers) 114* LSA
What for horsepower do you think this will be laying down?? He's asking for a stock LT1 and $2800 for the 383 motor.. what do ya guys think?
Check around to see what the parts cost to make a 383 LT1 with similiar parts. That CC305 is an awful small cam for a 383. As for the head porting it would depend on how good the machine shop was at porting LT1 heads. You could always ask for the flowbench numbers for the heads, if he can't get those then I would be concerned about the head work.
Guest iskone
Not knowing what they did to the heads(good work?) I'd say 375hp
You need the head flow numbers! With out them or a dyno sheet it isn't worth the money.
