naplesZ Posted June 14, 2004 Share Posted June 14, 2004 Will a N47 head work on a n42 block?If so does anything need to be done? Most of the search topics were about which head is better. Quote Link to comment Share on other sites More sharing options...
Mack Posted June 15, 2004 Share Posted June 15, 2004 I think the N47 head came on the N42 block, stock. well, thats if we are talking about a 280z/zx N47, as I am not sure what block the maxima N47 wass on. hope this helps.... Mack Quote Link to comment Share on other sites More sharing options...
Synlubes Posted June 15, 2004 Share Posted June 15, 2004 Will a N47 head work on a n42 block?If so does anything need to be done? Most of the search topics were about which head is better. Yes. N42 has square exhaust ports and a N47 has round exhaust ports. The N47 head (as far as I can remember) does not use a solid cam and oiling tube like the N42. I have used a square port header on the round port N47 head with no problems. I used 1 round port intake / exhaust gasket against the head and then a square port gasket against the header. No race motor, but I ran with this setup for a bit over 3 years with no problems or exhaust leaks. I would recommend using a good quality header with a nice thick flange with this setup. This info is for the Z N47 head, not the Maxima N47 head I heard of. Quote Link to comment Share on other sites More sharing options...
