pshepard327ci Posted June 14, 2004 Share Posted June 14, 2004 Ok.. i think i got most everything figured out, except the coil. I checked the voltage across the + - and i get something like 2.4v, but when i take off the wires and measure across them i get 12v. is there a reason for this, is this correct, i still doesnt want to spark or do anything except trying to start. if someone could please help me figure this out i would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
fl327 Posted June 14, 2004 Share Posted June 14, 2004 have you checked to see if the power source from ignition/acc has 12v or so while cranking? one connection at the key source grounds out during cranking. Quote Link to comment Share on other sites More sharing options...
pshepard327ci Posted June 14, 2004 Author Share Posted June 14, 2004 i actually have it wired directly to battery right now, to see if i could get it working. Are you just supposed to get 12v from the + and - off that this right on side of coil. because off of that i get 12v. just trying to figure this out. thanks Quote Link to comment Share on other sites More sharing options...
fl327 Posted June 14, 2004 Share Posted June 14, 2004 check to see if coil transistor is wired correctly? Quote Link to comment Share on other sites More sharing options...
pshepard327ci Posted June 14, 2004 Author Share Posted June 14, 2004 it is wired per the your writeup in the sticky post. that y/w going to y/w on ecu pin. maybe i connected it to wrong y/w i know there was two, but im pretty sure i tried both with no different effects. Quote Link to comment Share on other sites More sharing options...
