Guest Anonymous Posted November 27, 2002 Share Posted November 27, 2002 You are supposed to tailor your cross hatch with the rings you are using, and I am using Crome-Moly this time for nitrous purposes. How should the cross hatch be changed from stock. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted November 27, 2002 Share Posted November 27, 2002 the type of rings determines the pattern and grit needed http://www.aera.org/Tech/tb687r.htm http://www.kb-silvolite.com/speclear.htm#CHART http://www.totalseal.com/howdoo.html http://www.holley.com/HiOctn/ProdLine/Products/IEC/IECP/Ring.html http://www.babcox.com/editorial/ar/ar110060.htm http://www.axtellsales.com/NewFiles/HowTo/How%20To%20 PDF/Piston%20clearancing%20and%20Ring%20End%20Gap%20Instructions.pdf http://www.hastingsinc.com/Service%20Tips/ring_installation.htm Quote Link to comment Share on other sites More sharing options...
