Guest Cronic Posted June 29, 2004 Share Posted June 29, 2004 I replaced my injector clips and everything was happy for about 20 miles, then all the sudden the car feels like shit. It bogs and such as soon as I step on the gas or get any kind of boost going to it. The narrowband A/F Guage goes straight red, and off the gauge at this time. Now I've rechecked the wiring, the car idles, and I believe they are all hooked up to the proper cylinders... What else could this be?? Quote Link to comment Share on other sites More sharing options...
wigenOut-S30 Posted June 29, 2004 Share Posted June 29, 2004 did you solder the new clips in or did you clamp them in? I replaced mine when I put the turbo motor in and had a slight problem with it missing on one cly. I found that the clip was not all the way on.. I unhooked it and cliped it back on and it smoothed out. This does not sound like your Z is doing this though. Could it be something else? I would try cleaning the contacts of the ECU as well as the AFM and the fuseable links. At least that will be a good start. Quote Link to comment Share on other sites More sharing options...
Guest Cronic Posted June 30, 2004 Share Posted June 30, 2004 Solder, and I've cleaned the connections to just about everything... The car's old, and tired.... I just love it too much to give it up. 160K miles, original engine, 1983. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted June 30, 2004 Share Posted June 30, 2004 dont give up on it.. its pretty much the only cool nissan in tampa mike Quote Link to comment Share on other sites More sharing options...
Guest Cronic Posted June 30, 2004 Share Posted June 30, 2004 Like... IT stoped today... wtf. Just runs normal now... cept for a tapping in the head... Quote Link to comment Share on other sites More sharing options...
Guest Cronic Posted July 12, 2004 Share Posted July 12, 2004 It started up again a couple days ago, and I can't figure it out. Im sure this has nothing to do with the clips... Im thinking either the regulator or the MAF is going bad. I pulled the vac line from the regulator and the idle went up. So I assume that's good. I dont know how to test the MAF. So I think I'm going to the junk yard this weekend to pick up a used one... Anyone else have any ideas? Quote Link to comment Share on other sites More sharing options...
innerware Posted July 12, 2004 Share Posted July 12, 2004 I had a similiar problem after I replaced my clips too. It was the wires that went to the temp sender and thermotime switch that also needed replacing. I could be driving along and it would choke up and die. If I moved the wires sometimes it would do the same thing. So I replaced them and the problem went away. I know you can buy the little harness that they come on. I got mine from The Z doctors in Richmond CA. I think you can order from them. Just make sure you don't mix up and cross the wires. It doesn't like to start when cold then. Hopefully this helps a little. Quote Link to comment Share on other sites More sharing options...
