383 240z Posted July 2, 2004 Share Posted July 2, 2004 I was wondering if any body on here can tell me what other engines used an injector that I can put in to a 350 (stock) TPI manifold to use on my megasquirt project engine? I have a good motor here that I can stuff in my Z just so I can drive it for the first time in over 5 yrs. I'm hoping that a similar sized injector can be found in a more popular application like a 3.1 liter front driver that the local yard seems to have a TON of. Keith Quote Link to comment Share on other sites More sharing options...
Guest erics660z Posted July 11, 2004 Share Posted July 11, 2004 Summit sells Ford motorsport 24lb. injector, (recommended to me, and currently in my 400 TPI motor) or Accel injectors for $220 or $230, respectively. Hard to beat a new injector for cleanlyness/reliabilty. (Especially on a new motor ie: Are your valves adjusted wrong, or is that injector not firing.)...Just me... I chased down phantom vacuum leaks, ignition, valves, etc., before I realized my not used for three years injectors we're no good...maybe the same as a junkyard injector?..I'd stick to recently wrecked cars, with intact fuel systems. Eric Quote Link to comment Share on other sites More sharing options...
383 240z Posted July 12, 2004 Author Share Posted July 12, 2004 thanks for th tip on the ford injectors, I'm willing to spend that kind of money I just dont have the $400 I was looking at before, as for the what might be wrong I will have a TON of second guessing to do as These will be put in my Megasquirt powered motor!! Keith Quote Link to comment Share on other sites More sharing options...
