anyone installed a knock sensor in an L28?
zredbaron
hey guys...i was wondering if anyone has installed a knock sensor in an L28, if so...where?
here is where I put mine...
this is an old pic, but its where i installed the knock sensor.
it doesn't seem to be doing its job. if my octane is less than ~97, i hear the detonation warning sounds under load.
i am using the electromotive hpv-1 direct ignition setup.
(and btw, i finally get my sunbelt head this week :D )
The stock location on the F54 block L28et is on the passenger side, quite high on the block between cyl 4 and 5. I run a GM knock sensor with my SDS, but I am going to change to the stock nissan sensor when I change the engine. The GM sensor has a different tuning, and is picking up noise (Valvetrain?)and backing off the timing. I have it set so low in sensitivity that it is pretty much shut off. Can you adjust the sensitivity of your knock sensing on the HPV1? I think that a higher mount would likely work better for you. Closer to the source of vibration.
As with you, I know when I get a bad tank of gas. I just back off the timing a couple of degrees under boost until the next fill-up. SDS is nice that way for quick adjustments.
Doug
