Kevin Shasteen Posted July 12, 2004 Share Posted July 12, 2004 In the last few months my 1978 280Z 2+2 became slower and slower to start: on a cold start or a hot soak start. Last week I went out to drive the Z and the engine just turned over and over and over without ever starting. I could smell the fuel coming from the intake so I knew I was getting fuel. I pulled a few spark plugs just to make sure and confirmed the plugs were getting plenty of fuel. Keep in mind this whole time my Z has about 200,000 miles on it and is bascially bone stock: it still has 4 original injectors on it. Anyway, I began checking if I was getting spark to the usuall suspects: 1) Fusible Links...checked out good 2) Fuse Box....checked out good 3) Coil was getting +12 to the coil but no spark out of the coil 4) Pulled a coil from my International 4x4 and swapped it on to my Z; and my Z still would not fire. (I was so sure I would have to buy an ignition module or ignition relay ) 5) Decided to pull the coil off the Z again 6) This time I scraped the Coil Bracket mating surface clean with a wire brush 7) I also scraped the maiting surface on the fender apron where the coil bracket mounts. 8) Remounted the coil on the Z Upon cranking the Z this time it cranked for about 10 seconds and then fired up. Woo-Hoo! Killed it and re-fired it three more times just to make sure it wasnt a fluke. Each time thereafter the engine fired up in about 2-3 seconds the way its suppose to start. Just wanted to relay to everyone who has engine prob's: sometimes the best thing is not to replace a part - instead, sometimes the best thing you can do is to remove and scrape the ground's mounting surface to all the wiring connections. My Z may be original...but she's get'n old. I'm almost afraid to start her up these days, just knowing how hard some parts are to find. I guess when she finally gives up the ghost it will be V8 time. I cetainly didnt want to replace an ignition module or ignition relay...as expensive as those parts can be from Nissan or some other parts house. I believe I got lucky this time...just thought I would share my story just in case someone else ever experiences what I experienced. Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
johnc Posted July 13, 2004 Share Posted July 13, 2004 Another good thing to check when these symptoms occur is the negative cable from the battery and any chassis grounds. Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted July 26, 2004 Author Share Posted July 26, 2004 Well the saga continued for a little while longer. After thinking I fixed the problem, which resulted in my initial post on this thread, I drove the car later that week into town only to realize my problem was still there. Luckily I was able to push start the car to get it home. This was puzzling to me. Why would it start up perfect on a cold start yet refuse to start on a heat soak start up. As the previous post implies the engine was getting plenty of fuel so I knew the fuel pump and injectors were working. I had a hunch it might be the transistor ignition module or an ignition relay (again). So I consulted the Factory (Life-saver) 1978 Datsun 280z Service Manuel for testing the transistor module. There are about 5 tests you can perform on the module with 4 of the tests being conducted with a multi-meter and 1 of the test being done with an Oscilliscope (sp?). The fourth test indicated my distributor's pick-up coil was defective. So I removed the cap-rotor to check the air gap....which is only suppose to be between .008" to .016". Mine measured right at .065"; it was a wonder my engine even started at all. I adjusted the pick-up coil's air gap to .010" and the car fired up immediately. That Factory Service Manual has saved my wallet more money than I can shake a stick at. Anyway-just wanted to relate the final (hopefully) chapter to this saga incase someone else finds themselves in the same spot. Its been a crazy saga that began about a year ago with a fuel relay. This then transitioned into the dead battery-bad alternator game, then some inline fuses, an ignition relay, some bus fuses, an ignition coil along with a non-factory blue wal-mart plastic bag being sucked up into my air filter housing. All this over the span of a year. I beleive I finally have the ole gremlins whooped: Yee-Haw! I guess the moral to this thread is to never give up on these old cars that most of the previous owners neglectedl....AND to be sure and find yourself a Factory Sevice Manual for your year/model Z. Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
