Guest lazd Posted July 18, 2004 Share Posted July 18, 2004 I've got a set of 300ZX Z32 brakes and the entire braking system, can this be used on a 240Z? Can I swap to 5 lug hubs? Would the install be a huge challenge? Is ABS possible? Wouldn't really be worth it to me unless it was WAY easy. Anything else I should know? Other suggestions as far as braking systems? Quote Link to comment Share on other sites More sharing options...
datsunlover Posted July 18, 2004 Share Posted July 18, 2004 Hey man, I dont have all the exact info on this... but if you do a few searches, it's all here. As for the dificulty, well.. that depends on your skills.. or bank account I supose.. (ie; if you can't do things yourself, and have to pay for work done,) Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted July 18, 2004 Share Posted July 18, 2004 I run Z32 brakes on my 240Z - Is it possible? - Yes. Is it easy? - NO. If you can run a lathe and mill, it is reasonable in cost. If you have to pay someone, you would be better off selling the Z32 parts to a 240SX guy as they bolt on to that car and buying a well designed kit for your Z from Ross at Modern-motorsports or Dave at ArizonaZcar. As for ABS - with enought time and money, yes it can be done. Would it work correctly on a car that weighs 1100 lbs less - who knows? You would be in uncharted territory. Z31 hubs are a bolt-on for the early Z. Rear stub axles need to be re-drilled for 5 lug. Doug Quote Link to comment Share on other sites More sharing options...
Guest lazd Posted July 19, 2004 Share Posted July 19, 2004 darn, is there anything useful from my 300ZX that i can stick on a 240Z? Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted July 20, 2004 Share Posted July 20, 2004 Not easily or affordably. Quote Link to comment Share on other sites More sharing options...
