my door open light
Guest 007fastZ
Guest 007fastZ
my problem is my door open warning light comes when i'm going around curves or big bumbs, i have a 280zx and when i push the middle of the door the light will go on but if i push towards the end where in shuts it doesns't. Any suggestions?
Chris
Guest starfuryz2040
Did this work? If not......
Look at your striker plates. They are those pieces of metal that stick out from the door that allow the door to have something to grab onto to actually shut and lock. On this metal, there will be a plastic tube. If this plastic is other wise broken or missing, then your door will rock a little and set off the door sensor.
Could be the first thing said, but the striker could be it as well.
