dune333racing Posted July 20, 2004 Share Posted July 20, 2004 Has anyone ever mated a small journal engine with the t-56 6 speed. I know that the flywheel bolt pattern is different than the large journal engines. I know that centerforce makes a retro fit flywheel for the older style large journal engines but I am not sure about the older small journal(283,302,327). Also if anyone has any tips or tricks or pics of the mounted that would be helpful. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted July 20, 2004 Share Posted July 20, 2004 Has anyone ever mated a small journal engine with the t-56 6 speed. I know that the flywheel bolt pattern is different than the large journal engines. I know that centerforce makes a retro fit flywheel for the older style large journal engines but I am not sure about the older small journal(283,302,327). Also if anyone has any tips or tricks or pics of the mounted that would be helpful. I have a T-56 mated to a small journal 327. The bolt pattern is the same as a large journal. I did have to use the centerforce flywheel and dual friction clutch setup. Go to centerforce.com for part numbers. Quote Link to comment Share on other sites More sharing options...
