Guest PROJECTRB240SX Posted July 23, 2004 Share Posted July 23, 2004 DOES IMPALA AND CAPRICE LT1 ENGINE USE THE SAME MOUNTS? I'M WONDERING BECAUSE I CAN GET THESE FOR PRETTY CHEAP AND WAS WONDERING IF I'M GOING TO HAVE TO GO THROUGH THE ADDED HASSLE OF TRYING TO GET IT TO FIT DIFFERENTLY? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 23, 2004 Share Posted July 23, 2004 Same thing...same block as other LT1s..... Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted July 23, 2004 Share Posted July 23, 2004 Do you happen to know if they are 2 bolt mains or 4? The GM Parts Dealer for my company says 2-bolt. Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted July 24, 2004 Share Posted July 24, 2004 Also will the lt4 conversion work on the impala or caprice engines? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 24, 2004 Share Posted July 24, 2004 Likely 2 bolt. As for the LT4 conversion, I don't see why it wouldn't work, but it's a crap load of $$$ for the conversion parts for very little gain. Get a set of aftermarket heads (or a good port job on your heads), a good Crane or Comps cam, port your intake and get a bigger throttle body, and get a good dyno tune. Also, remember, the Caprice also came out with the L99 (4.3 liter LT1). They look almost identical, except for the 4.3 stamp on the rear of the block Tim Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted July 24, 2004 Share Posted July 24, 2004 Yeah these are LT1 motors... So over 100hp/ft-lbs is little gain? What would your idea of a good setup for street use be? I want at least 400hp and 400ft-lbs of torque, the power band needs to be pretty wide, and its needs to get good fuel economy..... from every dyno sheet I've seen with the LT4 conversion, Block Hugger Headers, 2.5" exhaust, 30lb injectors and 58mm TB it was doing everything I would ask of it. I'm also going to do a 383 Stroker with this motor as most likely I'll have to freshen up the lower end a bit anyway.... some of them have decent mileage to them. Also would I have to modify anything to get the A/C compressor to fit? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 24, 2004 Share Posted July 24, 2004 Drop Mike a PM. He ran a pretty highly modded LT1 in his Z, and then went LS1. His user name is MAS280..... Tim Quote Link to comment Share on other sites More sharing options...
