Guest 2slo4u Posted July 27, 2004 Share Posted July 27, 2004 Just completed the 280/300 ecu swap and... IT'S ALYEEEEV! Thanks to all of the genius folks on this site, I was able to complete the swap of all components this morning. It cranked right up on first try. Now I'm just trying to cure a slight miss. I double checked the distributor sensor wheel and it's in correctly. -Still have to run to the hardware store for a tube to connect the air filter to the mas. I have it temporarily connected with aluminum tape because the hot air from the engine was causing it to run very rough. -I posted the other issues I'm having on the ecu swap sticky, but..... ITT"SS ALIIIIIIIVE!.........IT'S ALLLLLIIIIVE!.... 81zxturbenstein 95slobaru impreza Quote Link to comment Share on other sites More sharing options...
Guest RCNSC Posted July 27, 2004 Share Posted July 27, 2004 Whoo hoo. Sounds fun. Quote Link to comment Share on other sites More sharing options...
Afshin Posted July 27, 2004 Share Posted July 27, 2004 HI, glad to hear it's running. double or triple check all the connectors and pins to make sure all contacts are good, no vacuum leak .....they are the most frequent culprits for hesitation...... Start with the timing set at 20-22 and play with it from there. Lastly, are you running the old repaired previously burnt ecu, or is this a solid unit ? Quote Link to comment Share on other sites More sharing options...
