Guest dvlax28 Posted July 27, 2004 Share Posted July 27, 2004 240z 73 i took out both of the tail light harnesses and now i need to put them back in after repair/cleaning. i know the turn signal has 3 wires going to it because it has to blink, right? does it matter for the other 3 bulbs? some have 1 connection in the bayonet fitting, others have 2....is the a picture anywhere of which bulbs go where in the plastic tail light housing? thanks jason Quote Link to comment Share on other sites More sharing options...
fl327 Posted July 27, 2004 Share Posted July 27, 2004 From my past experiences I have found that the turn signal bulbs are different from the others and will only go in the right spot, the other lights dont matter so much, just drop all the bulbs in and the natural length of the harness should place the bulbs where they need to be, you may have to move one over and so forth, but it should be quick... Quote Link to comment Share on other sites More sharing options...
Guest dvlax28 Posted July 28, 2004 Share Posted July 28, 2004 yeah i decided to just put the key in and use reverse, blinker, running, brake lights to figure out where the bulbs go. i cant remember .... i know the reverse light is the white one, but if there are 4 locations on the tail light, which is supposed to be the brake light, and the blinker and the running lights? see a basic sketch: http://www.geocities.com/dvlax28/240ztaillights Quote Link to comment Share on other sites More sharing options...
