327 cams
Depends on which Comp Xtreme cam.
Go to their catalog:
http://compcams.com/catalog/056_057.html
(That's the page for the flat hyd. Xtreme cams)
and pick a cam. Then look over to the right in the Valve spring column, and note the part number. Go to the valve spring page with those springs spec listed:
http://compcams.com/catalog/303.html
and check the specs for those springs (986-16 or 981-16).
If your springs have alot of miles, you're better off just replacing them with the correct ones.
