Guest JerameyFranklin Posted August 11, 2004 Share Posted August 11, 2004 heres the dilemma. I've just recently acquired this one of a kind 76 Hybrid 280 Z. It runs wonderfully...that is, if i can get it going. It seems that every time i try to start it up, it just clicks, and doesnt even try to turn over. The only way i can get it to run is if I pop the clutch, but i would, however much rather just start it up....... Help....is it the starter perhaps???? Quote Link to comment Share on other sites More sharing options...
datsunlover Posted August 11, 2004 Share Posted August 11, 2004 By 'pop' the clutch I assume you mean bump start.. and it runs fine after that? Id say the starter has problems, (worn solenoid/contacts inside the startor) or it is a bad conection somewhere in the starting circuit.. I'd suspect a bad ground.. Quote Link to comment Share on other sites More sharing options...
Guest JerameyFranklin Posted August 11, 2004 Share Posted August 11, 2004 yessir a bump start is what i mean. I had a feeling that, that was what it was but wasnt completely sure. Plus, i didnt want to spend any xtra money for something that didnt need to be replaced. Quote Link to comment Share on other sites More sharing options...
Guest butlersZ Posted August 11, 2004 Share Posted August 11, 2004 What I would do first is run a hot wire from the battery straight to the starter solenoid and see if the starter bumps and turns the engine over. If it doesn't turn then it's a problem with the starter. If it turns then I would check the grounding on the car and then proceed to the ignition switch and starter relay(if one is present). Make sure the ignition switch is getting power. Just use a simple test light or multimeter to check connections. Hope this helps. Quote Link to comment Share on other sites More sharing options...
