Guest butlersZ Posted August 11, 2004 Share Posted August 11, 2004 Quick question...On a '78Z there are three wires coming from the fuel sending unit, black, yellow, and yellow/green. Which is which? I assume that the black is ground, the yellow hot and the yellow/green is the sending wire? is that correct? My chilton book sucks and doesn't show anything. Is there a way to find out with a multimeter? Quote Link to comment Share on other sites More sharing options...
wal280z Posted August 11, 2004 Share Posted August 11, 2004 Quick question...On a '78Z there are three wires coming from the fuel sending unit, black, yellow, and yellow/green. Which is which? I assume that the black is ground, the yellow hot and the yellow/green is the sending wire? is that correct? My chilton book sucks and doesn't show anything. Is there a way to find out with a multimeter? black = ground yellow = float level yellow/green = low fuel level indicator. This is off a '77, (yellow/green is yellow/blue on mine). Wayne Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted August 12, 2004 Share Posted August 12, 2004 The 78 FSM also shows yellow with blue stripe to the fuel warning lamp. That wire and the yellow that goes to the fuel gauge both route thru a 10 amp fuse to the ignition relay. LARRY Quote Link to comment Share on other sites More sharing options...
