Z-TARD Posted December 5, 2004 Share Posted December 5, 2004 I pulled a set of 300ZXT (86 if I remember correctly, not the 88SE) CV's a few weeks ago, they look like they will plug right into a standard R-200 open diff. They dont look like the shaft ends from the R-200 VLSD I have though. Looks like I'll have to find some out of an 88SE. Mike Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted December 6, 2004 Share Posted December 6, 2004 The RH shaft needs to have the long nose with splines to engage the viscous unit in the diff. The other shafts may plug in, but you won't have an LSD. Can anyone give me the diameters of the 88SE shaft to confirm that they will work in the Z32 N/A diff? We are OK on the spline count.... Thanks Doug Quote Link to comment Share on other sites More sharing options...
Guest Fredrik280zx Posted December 6, 2004 Share Posted December 6, 2004 http://www.purenissan.com/r200_front_lsd.htm Quote Link to comment Share on other sites More sharing options...
Guest Fredrik280zx Posted December 6, 2004 Share Posted December 6, 2004 http://www.purenissan.com/r200_front_lsd.htm this is the same unit that´s in the z31t, how can they cost 500$ at a junkyard? Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted December 7, 2004 Share Posted December 7, 2004 Fredrik - Welcome to HybridZ - I'm wondering why you posted in this thread - as that isn't a R200V diff? If you search, you will know why they are $500 used. Doug Quote Link to comment Share on other sites More sharing options...
Sean73 Posted December 14, 2004 Author Share Posted December 14, 2004 Doug - I will take the measurements this evening. I haven't worked on this for while, but I confirmed on the bench that the 88SE halfshafts do indeed snap right into the 240SX VLSD carrier. Sean 73 240Z Turbo Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted December 14, 2004 Share Posted December 14, 2004 Thanks Sean - Looking good. I found a place that has new 88SE shafts in stock. Not cheap though. Doug Quote Link to comment Share on other sites More sharing options...
Sean73 Posted December 17, 2004 Author Share Posted December 17, 2004 Doug Info on the 88 SE shafts OD of the splined portion of the shaft that goes into the diff: 30mm Hope this helps Sean Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted December 17, 2004 Share Posted December 17, 2004 Thanks Sean - Looking good. I found a place that has new 88SE shafts in stock. Not cheap though. Doug I have the 88se installed in my 260 right now with the custom shaft build up a per James Thagard, but I also have a complete spare 88se diff w/o the shafts... Can you provide the info on where to get the new 88se shafts? It's a shame only the inboard portion is needed for the custom shaft build, so having to buy the whole new shafts is a waste... Quote Link to comment Share on other sites More sharing options...
