Air intake sensor location
jkube
Hope you guys can help with this, I am installing a 280zxt motor into my 240z and plan to use Megasquirt to run the fuel system.
My question is where do I install the Intake air temp sensor?
Do I put it into the freash air intake ( before the turbo) or into the J-pipe (before the throttle body).
Seems to me it should be the j-pipe, but I am unsure of this
thanks
Jeff
A buddy of mine tapped his 60mm throttle body spacer to run one a Intake Air sensor. I have my intake tapped for one, currently plugged.
You can run one in the jpipe, I wouldnt do it since odds are you are going to intercooler it. You can also run it right before the throttle body in the intercooler pipe.
Guest Chris240turbo
I would say before the turbo if not intercooled, and in the upper I/C pipe, after the I/C and before the TB if the motor is 'cooled, I believe my haltech manual says this too, but i'd have to look....
Guest Chris240turbo
