Guest 305240 Posted August 17, 2004 Share Posted August 17, 2004 I'm running a 72 240 with flairs. I have G60x14's on the rear. I also have about 2 to 3" clearance above the tires. The other day I discovered each rear spring had a set of twist in spacers in them. Well now, they just won't do. My question is, can I use a 280 spring? I'm assuming they have a higher spring rate. Any help would be appreciated to get the rear of my car in the air. Not down as so many people want. Quote Link to comment Share on other sites More sharing options...
nullbound Posted August 17, 2004 Share Posted August 17, 2004 a 280 spring on 240 struts will raise your car. that's how my car was raised originally to allow for a 27" diameter tire. depending on how much you need/want to raise, just changing the spring hats from 240 to 280 will give you about 0.75". Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted August 17, 2004 Share Posted August 17, 2004 Ok, If I change to 280 springs and use the 280 hats, how much rise can I expect? I'm hoping for 2 to 3" over the tire so it won't rub my flairs. The car isn't being built for auto cross or anything like that. I just want it to look like an old style street machine. Quote Link to comment Share on other sites More sharing options...
nullbound Posted August 18, 2004 Share Posted August 18, 2004 if i recall correctly, it will give you 2 to 2.5" Quote Link to comment Share on other sites More sharing options...
