Guest bastaad525 Posted August 18, 2004 Share Posted August 18, 2004 This is the last available port on my intake manifold... been adding a few things that need to be hooked up to the manifold, and really don't want to start putting tees off of every port. I had forgotten this port was there.. it's got a plug in it at the moment. I want to unblock this one and run my wastegate/boost controller signal from it. However, I'm a bit concerned about the port's placement. It's right at the beginning of the #5 intake runner, ON the runner, as opposed to being on the main body of the manifold. Would there be any problem with using this port because of that? Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted August 19, 2004 Share Posted August 19, 2004 I guess that's a no? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted August 19, 2004 Share Posted August 19, 2004 Put your boost gauge signal there and see if you get any different readings... Quote Link to comment Share on other sites More sharing options...
