I need help with an 81ZXT dizzy
Guest 305240
Guest 305240
Does anyone know of another dizzy that will work in an 81ZXT? How about an 82ZXT? I know the ECU's are different. I also know the 81 doesn't have a knock sensor. Will a 81 na work? All info would be greatly appreciated. Thanks.
Guest 2slo4u
My 81turbo has the knock sensor. I swapped the 83turbo distributor into my 81 so I could do the ecu swap. You will also need to change the oil pump shaft that drives the distributor to the 82-83turbo model. The 82-83turbo distributor will plug right in to the four pin black harness that would go to the crank sensor on the front of the engine. I ran mine with the 81 computer for a few days and it did fine.
81zxturbo
95slobaru
