Headlight issues...
Guest Cronic
Guest Cronic
Sorry if this is kinda long...
Here's my problem, my driverside headlamp is dim when brights OR low beam is on. I've tried regrounding the lamp, and that didn't work. I checked the voltage over the lamp, and it's only getting about 5-6V. Im pretty sure they're suposed to see 12... So I hardwired it to the batery, and BOTH lamps came on, and both dim. When I turned the lights on, they both came on normal.
Any clues?
This might sound stupid.. but does the car have some sort of 'daytime runing' light system? My 93 king cab has some sort of setup like this, and it just drops voltage to thelights to make them come on dim.. Other than that, I'd think there is a short/bad wire somewhere in your harness.. or maybe the headlight switch assy?
