80LS1T Posted January 8, 2003 Share Posted January 8, 2003 I was trimming back my bird nest tonight and I cam to the I.C. Ignition Unit wires there are 2 Brown and Blue (I think???). What are those for and do I need them for my LT1? Guy Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted January 8, 2003 Share Posted January 8, 2003 Those wires were originally for the ignition module. The blue one is for the tachometer signal. Trace the blue one back, and it eventually goes into a resistor and comes out as LGW (light green, white). The LGW wire traces to the tach. I took the resistor out of the line on my install with an HEI distributor, and just spliced the L and LGW wires together. The BR (brown) wire, which eventually is spliced into a BW (black, white) wire is the positive voltage to the coil. On my HEI, I connect that directly to the + terminal on the cap. Your LT1 may need all of these to terminate to the computer, I don't know LT1 stuff. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted January 8, 2003 Author Share Posted January 8, 2003 I thought those wires were attached to the back of the coil? Guy Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted January 8, 2003 Share Posted January 8, 2003 Page 220 in the Haynes manual spells it all out. Also page 124. Quote Link to comment Share on other sites More sharing options...
